Operating temp yz250f
Anyone know what the normal operating temp is for a 250f? I got some of those temp stickers but not sure what temp to be looking for.
Well, she'll boil after 212 with water or higher temp is other fluids unless the cap holds pressure in. I have a performance can that runs at 180. There is no thermostat on this bike, so if it doesn't boil over, you're good. Book calls for replacement of the antifreeze in 3 years, but I do it more often than that. It needs to run hotter than 175 or deposits will build up in the combustion chamber and intake tract.
Are you having problems that you are trying to diagnose?
No problems just with the temps outside being as high as they are and the muddy tight terrain i just want to make sure my bike isnt running hot. Also want to make sure it isn't jetted a little lean.
