cfr70 smoking bad
I have an 2004 crf70 that I just can not get to stop smoking. So far I have had an engine shop replace the valve seals and clean up the valves, bored the jug 1mm oversize, installed a new piston and rings, and put back together with new gaskets and o-rings. This thing still smokes like before I started. When it was apart, we checked the head and jug for cracks and could not find anything. Twice when I pulled it apart, the cylinder walls and piston were covered with oil. I am stumped. Where is all the oil coming from???????? Is it possible there is a crack somewhere that is not visible?? I made sure to put the ring gaps spaced out and followed the manual for reassembly. Compression check right after the rebore was at 120 psi. I assume this will get better with some break in time. What else can I check???????????
Did you put back all the right gaskets? If I remember correctly, there are some small o-ring type gaskets that could be easy to overlook. Also, you mentioned the valve work, but were the valve guides checked? If they're sloppy, it might make the seals wear out fast.
Did whoever sold you the piston give you the correct rings? How did the shop check for cracks? And what was the piston clearance when they were done? I know people who have had back experiences with machine shops.
Just throwing out some ideas. You've got a puzzle on your hands. Good luck.
I used an aftermarket gasket kit from Moose. The 2 orings were not the exact shape as the originals so I bought those from Honda. The piston and rings came as a set, aftermarket though. Took the piston to the engine shop along with the jug; had good results with the shop before so dont think that is the problem. The same place did the head work. Is it possible that it will take alot of break in time to seat the new rings good? What is normal amount of smoking right after a rebore and ring job?
My CRF50 didn't smoke at all when brand new. I don't know if there was some kind of run-in at the factory, though. I've rebuilt car engines and never had them smoke either when first fired up after the rebuild. Can't say this if this is typical or not, especially for motorcycles, but I wouldn't expect much.
How much time do you have on the engine after the rebuild?
About 30 minutes of runtime. Starts easy and idles and sounds good but smokes like crazy.
Double check to make sure the corrugated oil ring ends are not overlapped, allowing the oil to bypass and get up into the combustion chamber. Also check and see if the upper rings have a letter stamped near the end, the letter side is supposed to be facing UP. If those two rings are different colors, the flat black ring should be under the shiny ring.
I ran the bike this weekend about 2 hours and the smoking is signicantly less. Im guessing that the rings needed more break in time. Will run more this coming weekend and hopefully everything will be back to normal.
Yup, what he said. Also possible the 'repair shop' has done a less than stellar job on assembly / boring.
I ran the bike for about an hour a day for a couple weeks and the smoking gradually went away. It really ran well and started easy. I could also notice an increase in power from before the rebuild. Put it up for sale; first person in the door bought it. And now back to my 3 wheeler resto!!
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
