ktm 450 exc 5 gears???
hi, I'm new to the forum but not new to bikes.
I'm currently interested in a 2003 ktm 450 exc, it goes well and its looks good.
http://www.bikesales.com.au/Tig/UI/P...&tabID=1409177
There's a few photos of it!
But, there's one thing about it I'm not sure about, the guy said that it's only got 5 gears.....
Now as far as i know, ktm didn't make a 450 exc with only 5 gears since even before 2003, also the ktm dealer that I spoke to said the same.
I want to know why this one apparently has 5 gears and not 6 like all the others?.
Different gear box put in? Broke a gear some how? Please list all the possibilities that could be the reason for this so that I can make good a decision on buying it.
thanks!
Have you looked at it in person, taken it for a test ride? What about asking the seller to clarify?
Hi there,
The latest one definitely has 6 gears.
The approximate speed range of each gear can be seen on the chart below.
I also re-geared it more like the XCF-W. This is the dashed line down in the lower cluster of lines.
Probably better to gear it like that when you're going off road.
Ron Daniels
All 450 EXC's have always had 6 speeds.
All EXCs have 6 gears, if it only has 5 available then the trans is messed up.
yer iv looked at it in person and talked to the guy again, he got mixed up with, 5 gears up measn 6 gears (1 down 5 up), so its all sort but thanks for your help everyone! :thumbsup:
Some sxs models had five, didn't they? But those are a real curiosity.
Most of the RFS SX models had 4 speeds but could be converted to 6 speeds.
its totally sorted, definitely an exc and definitely has 6 gears :thumbsup:
Yes, I have one converted, very easy and relatively cheap when you're in there.
Yes, 450 SXS has 5 gears from the factory. Its actually a 6 speed box, but a pin in the shift drum stops the MX riders getting lost :thumbsup:
I have had a couple, I removed the pin on one to make it close ratio 6 speed, on the other I fitted a full EXC 6 speed box.
