carb kit comparison
Also, that site is not Keihin, it is a site that sells used carbs, often garbage from what I have heard. No one has actually gotten a good deal. For example, that carb you are refering too looks very old and is only $150 or so less than brand new. To me it looks like a $200 carb at best and even then, not really worth it. I also doubt the carb you see is the one you'll get. It is just a picture they use.
Thanks for the clarification! I had not realized they were used, I'll be going with the SSW kit. Anyone know off hand if you need to change out the stock valves when using a stage 1 hot cam set up? Cheers, S.
