need help with a tourqe
i have a 2001 kx 60 that i dont know the oil screw torque specifications, i looked through the manual for an hour in the obvious places, but cant find it, anyhelp is appreciated.
Titghten until the bolt contacts the drain washer and case, tighten 1/8th turn. DO NOT OVER TIGHTEN.
Unless your torque wrench is properly calibrated and the fastener toruqe falls in the middle of the scale, you not use it.
To figure out a torque when a value is not specified, in your manual is a table of tpurques based on bolt sizes. Torque towards the low end of the scale.
