Is a spoke torque wrench worth it and how do I use it?
My spokes keep coming loose on my crf250r like most bikes. I never know how to tighten my spokes correctly though. It seems like some of them are clockwise and some are counterclock wise. I also stripped out all the nipples on my old front wheel but I just go new wheels so I dont want that to happen again. Is a spoke torque wrench worth the money though? And also in my manual it says the torque should be 2.7 but then some of the torque wrenches are set at 4.4 so is that fine or to tight?
This is the spoke torque wrench I was thinking of getting
One more question. I always just went on each spoke and tightened it(I would turn it a full turn or what ever it took). I read that you should tighten a spoke and then skip 2. But how do you do that? I would just go on the right side of the front wheel and tighten and then go over to the left side of the wheel. Is that how you are supposed to do it but skip 2. Or do you go back and forth between the left and right side. I know thats a confusing question but its hard to word it.
Thanks for any help.
I have a torque spoke wrench, works for me. Someone please chime in and teach us how to do it by feel or sound.
Proper method is to start with the spoke next to the valve stem, tighten that spoke no more than 1/4 turn, then skip 2 spokes and tighten the 3rd spoke(4th spoke from stem), which will be on opposite side of hub, again no more than 1/4 turn. Continue same count until you reach valve stem, then start with the 2nd spoke from stem all the way around again, then the 3rd from stem all the way around, then all spokes will have all been tightened no more than 1/4 turn. If more torque is needed do this sequence again until proper torque is reached on all spokes. Keep in mind this is assuming the rim is true to start with, if not you need to true rim first which is a completely different procedure.
Ok thanks. Im just going to buy the excel adjustaable spoke torque wrench. The manual says 2.7 ft pounds which is 32.4 inch pounds. Is this right? The fassco wrech is set for 4.4 ft pounds. What should the torque be set at?
If your standing on the sprocket side of the bike and tightening the spokes on that side which direction is tight? Up or down? Do all the spokes have to be the same tone when you tap them with a wrench?
Its just like tightening a bolt. Think of it as looking down on the wheel if the tire wasnt on there. You would turn the nipples clockwise to tighten. Now just reach around the rim and tighten the nipples.
When I built my front wheel this spring I used my inch pound torque wrench with an allen socket that fit the top of the nipple to torque them after I had it trued up. Now that its got a tire on it I would just use a spoke wrench to tighten.
Lefty loosy righty tighty
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
