Left turn signal won't work.
Hello all, I'm having a little trouble with my DRZ e. My right turn signal works just fine, but my left one won't work. The back blinker just stays solid Orange when I engage it and the front one doesn't come on at all. I'm a total n00b when it comes to this kind of stuff. I appreciate any help. thanks.
-MrMeh
Start by checking the bulb, is it burned out? No? Is there 12 volts at the socket when you turn the switch on? If there is 12 volts on the hot side; is the other side grounded? Are both wires connected to the wire harness (connections are probably behind the headlight cover)?
I'm guessing the front one is burned out and there is not enough current thru the back one to make the flasher work. Replace the front bulb and then it will work.
Agreed!
I also think that'll solve your problem.
