06' RMZ450, crash and petcock put hole in radiator
Anyone else have this happen?
Any solutions to stop it from happening again?
I have PWR oversize radiators, will braces fit?
I came close! Noticed on the weekend that I have an indent on the rad from the petcock. I'll be looking into rad braces
This was discussed back when the 06 was newer. Back then....I was told to remove the bolt securing the petcock to the mounting tab. Then replace it with a small zip tie. It isn't the most hi-tech setup, but it will move / break off if you crash.
THANKS! will do that today!
