2005 yz125 or 2008 crf250r?
i got a 2005 yz125 and im trying to decide if i should get a crf250r, the yz125 does have a few problems, theres jb weld on the case because the chain went through it and the front rim is bent slightly, i need new fork seal in it, shifter lever, and a clutch lever, should i get the crf250r or stay with the yz125?
bummpp
If youve got the money then yes. theres nothing wrong with 2 bikes.
are you going to race? why do you want to go from 2 to 4 stroke
If you cant afford to fix the things wrong with your yz125 why would you think you could afford to maintain a 250f?..a yz125 is about as cheap as it gets as far as maintainence and parts cost. a crf250 is about the most maintainece intesive bike you can buy
