My first YZ experience. Mixed emotions...
So, last week I decided to sell my CRF250 and CRF450 and cross over to the yamaha/ 2-stroke lifestyle. I bought an 05 YZ250 for a reasonable 2800 bucks for how clean it was, and decided to save the rest of my money for my remaining years at college.
Previous steeds (good riddance to that blasted 250!!):
I took it out the next day (Friday) and fell in love with the smells and power of the bike in the woods. It was a freakin' BLAST compared to my 450. Unfortunately, an hour into my ride, after a rocky section I seemingly had lost my first gear. It would just slip and buck under power, so I just blasted back to the truck in 5th gear on the fire roads, very disappointed with my recent purchase. So that night, I cracked the cases, and this is what I found:
This was 1st gear:
This was the 5th gear "dog gear" (why do they call them that?):
And this was the corresponding shifty forky thingy:
Heres an view of my engine internals... reminds me of one of Dirt Rider's long haul wrap-ups:
I was really surprised and slightly pleased to see the bill for this overhaul was only about 180 bucks including new gears, fork, and gaskets. I'm still waiting for the parts to come in, and can't wait to hit the trails again! Any advice on getting this thing back together? It feels just a little bit overwhelming at this point...
While you remember what goes where, bag and label your hardware so that you don't get it mixed up.
Use loctite where your suppose to, don't where your not.
Torque specs are important.
As overwhelming as it may feel, when its going back together everything pretty much falls into place and shouldn't be to challenging.
If you get into a bind, parts fiche and manual can be helpful...especially if the PO or previous mechanic forgot a shim or clip here or there.
May want to loosen that chain up while your at it.
...I was waiting for that one. I'll get to it as soon as I find my swing arm in my parts pile. I'm redoing the suspension while I have it apart.
nice bike. are you going to do the crank bearings while your in there? on an 05 you might as well.
My 2 cents.... since you've the whole bike apart, double check the wheel bearings and all the suspension bearings....
They aren't that expensive to replace, if needed. I'd also look at replacing the main seals at the crank.... they don't fail that often but since you've got the bottom end apart, might as well change 'em out.
All the rear end bearings were supposedly replaced, and they feel tight, I just checked the front wheel and it did have a bit of play. thanks for the advice guys. I think I may get the crank bearings changed out as well, only 50 bucks for some serious preventative maintenance.
I like what you paid for it, I'm going to be selling one this fall that will clean up to like new.
Put in WR426F gears. 3-4-5 are a direct fit!
The aluminum frame YZ's seem to hold their value very well compared to other brands, they're hard to come by in Oregon as well! They get snatched up fast.
+1 on Shrubs recommendation.. 3-5 WR gears are an amazing upgrade for the bike.. Really spreads out the power.. Also, second the recommendation on doing the crank bearings while you have it apart.. Cheap insurance..
As far as the failure, Id speculate that the tranny was already well worn by the time you bought it.. So dont bag the YZ too much, they are great machines :ride: I got four seasons out of my 05 and on my fourth season with my 07 with minimal issues :thumbsup:
same thing happened soon after I bought my 06 --it had been raced hard and I got a great price.
Fixed it and have had no problems since --as noted, while your in there replace bearings and anything that looks worn and when you get it back together you will be a happy man.
I stayed with stock gearing but the WR idea is a good one for trails --I may still do it at some point.
The WR gearing sounds like a SAWEET mod to do. I think I might have to do it for a winter project. As for the crank, I just ordered a new set of bearings and seals as well.
what was wrong with the crf250 you had ??
How would the wr gears be for serious hare scrambles. I'm running 15/50 which is great for top speed but in really technical riding is alittle tall.
The crf250 was just a bike I bought cheap (not running) "in need of a valve adjustment". The valves were in spec, so I did some detective work and replaced the rings. After that it ran great and I sold it for some profit. I didn't trust an 05 crf250's valvetrain to ride one myself.
i kind of didnt either, but i still ended up with a 05 crf250
Where did you manage to get all that for only $180? I need to replace the gears on my 125 and just 2nd gear is like $150 from
  • Similar Content
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
    • By fiat2nv
      Hi all, First post here. I need some help.
      Ive just bought an 05 yz 125 for a good price but it needs some work. One of the forks has some pretty severe pitting of the chrome on the stanchion towards the bottom near the brake caliper mount.
      Ive found a pair of good condition forks from an 04 yz250 for a very good price, from the research ive done its seems that both the 04 & 05 forks are 48mm but are different, with the 05 fork regarded as being better than the 04, but not as good as the 06 + sss forks.
      Im looking for the cheapest way to get me riding, Will I be able to make the 04 forks work with my 05 triple clamps, brakes, wheel, axle, spacers etc? If not does anyone know what hardware id need to make it work?
      Finally, as a last resort, does anyone know if i could swap the stanchion from the 04 fork into my 05 forks?
      Thanks, Andrew
    • By idratherberiding
      I bought a 2006 YZ250, have ridden it 5 times.  It needs some tuning, but I am not sure I'm keeping it so don't want to spend much on it.
      Has fmf gnarly expansion chamber and turbine core silencer.
      I ride about 1000 feet above sea level.
      I'm going to clean the carb and check the jetting.  What is a good jetting for me?  85 main jet?
      Also check the reeds.  Is there a big difference between getting aftermarket reed cage and reeds or just getting a cheap aftermarket set of reeds that fit the stock cage ie.  Boyesen Power Reeds?
      The other things I'm going to do is permatex all the joints in the exhaust system and a compression test.   It was 220psi 5 rides ago so I'm guessing itll be fine.  Its bogging a bit but I'm thinking its carb and definitely exhaust joint related.
      Let me know if I'm overlooking anything that could make the bike run crisper and more bottom end without throwing much money on parts
