TTR-90 Replacement Carbs
I have a 2000 TTR90 with a Mikuni 19mm carb. The bolt spacing on this carb is 42mm center to center. All replacement 19mm carbs have a bolt spacing of 48mm center to center. Is there an aftermarket carb or adapter plate or intake that will solve this problem or do I actually have to get the Yamaha OEM carb.
Is it necessary to have the carb heater on this bike? Will it affect starting or operation in any way.
I realize it's an old thread but i have the same question...Which mikuni carb works as a replacement of the stock one?
A little performance improvement is a plus but not required, just looking for a replacement that will let my kids be able to start it without having to pull the plug, dry it, and then get some ether. :)
I've read the VM22 works but haven't heard if it's a direct repalcement or if some other mods have to be done.
Thanks for any help.
And it's for an 05 ttr 90.
Did you ever find one, I need one now
