2012 kx450f suspension valving specs
For 2012 - this is what I measured.
Forks MID COMP
3 20 8 0.11
2 17 8 0.11
2 13 8 0.11
2 11 8 0.2
1 13 8 0.15
2 11 8 0.25
2 12 8 0.3
2 20 8 0.11
2 13 8 0.25
Reb
4 20 6 0.11
1 13 6 0.11
1 18 6 0.11
1 16 6 0.11
1 14 6 0.15
1 12 6 0.15
1 11 6 0.25
Base
16 32 6 0.11
1 30 6 0.11
1 28 6 0.11
1 30 6 0.11
1 28 6 0.11
1 26 6 0.11
1 24 6 0.11
1 22 6 0.11
1 20 6 0.11
1 18 6 0.11
1 16 6 0.11
3 14 6 0.30
No bleed stack
Shock Comp
12 44 12 0.20
1 38 12 0.11
1 34 12 0.10
1 44 12 0.25
1 42 12 0.25
1 40 12 0.25
1 38 12 0.25
1 36 12 0.25
1 34 12 0.25
1 32 12 0.25
1 30 12 0.25
1 28 12 0.25
2 27 12 0.25
1 25 12 0.25
1 24 12 0.25
1 23 12 0.20
Reb
6 40 12 0.20
1 29 12 0.11
1 40 12 0.25
1 38 12 0.30
1 36 12 0.30
1 34 12 0.30
1 32 12 0.30
1 30 12 0.30
1 28 12 0.30
1 26 12 0.30
1 25 12 0.20
Enjoy
Like wise!:thumbsup: I have not done any reading on the 12, same as 11. Spring in one side dampening in the other? I heard they were going to ditch it?
This is the 450 - so normal kyb sss stuff - but with some cost cutting measures.
Plastic spring seats with no conventional bushings, plastic ICS piston with no bushings (11 had this too)
The 250 has the SFF - and I have the 10 stacks too if anyone wants em, but I think it was posted.
Yep, thanks for that. I just read on trans. Why in the heck didn't they keep both bike the same? I hate when they do that.
That 450 stack looks decent right out of the box!
Thanks!!
looks good for faster riders IMO.
how feels the bike on the track?
looking at the midvalve, the only thing I don't like is the 2 17's on the comp side after the 20's. I like a nice taper. Maybe they ran out of 15's or 16's lol.
Sure would like to see it, Thanks
The mid is fairly stiff - feels somewhat harsh for many IMHO.
Shock this year is good - I run a different highspeed adjuster set up and usually mostly mess with quantity of face shims on compression side to suit the rider.
The rebound this year is updated to what I was running on the 09's for most people - so it's pretty decent. One of my pro guys is running it much faster - he is the only one i have departed far from the stock rebound stacks.
10 250 SFF
BASE
18 31 6 0.10
19 30 6 0.10
2 29 6 0.15
1 27 6 0.15
1 25 6 0.15
1 23 6 0.15
1 21 6 0.15
1 19 6 0.15
1 18 6 0.15
MID COMP
1 24 8 0.15
7 24 8 0.1
1 22 8 0.15
1 18 8 0.15
REB
6 24 6 0.11
1 22 6 0.11
1 20 6 0.11
1 18 6 0.11
1 16 6 0.11
1 16 6 0.20
2 15 6 0.20
clamped on 2 x 13.25 (I think - the thickness here is important)
Float as I measure it is .4mm. But my buddy has it at .35...so pick your poison on that one.
Shock is same as previous years.
@harrperf
What have you found to be the best valving setup front and rear on a 09YZ450F for a 220# 6' intermediate level MX rider with .48 front and 5.8 rear main springs?
10 250 SFF
BASE
18 31 6 0.10
19 30 6 0.10
2 29 6 0.15
1 27 6 0.15
1 25 6 0.15
1 23 6 0.15
1 21 6 0.15
1 19 6 0.15
1 18 6 0.15
MID COMP
1 24 8 0.15
7 24 8 0.1
1 22 8 0.15
1 18 8 0.15
REB
6 24 6 0.11
1 22 6 0.11
1 20 6 0.11
1 18 6 0.11
1 16 6 0.11
1 16 6 0.20
2 15 6 0.20
Are you running the HS spring perch that supports the face shims on the compression adjuster?? Basically a copy of the WP design. SDI makes it if I'm not mistaken.
Forks MID COMP
3 20 8 0.11
2 17 8 0.11
2 13 8 0.11
2 11 8 0.2
1 13 8 0.15
2 11 8 0.25
2 12 8 0.3
2 20 8 0.11
2 13 8 0.25
Reb
4 20 6 0.11
1 13 6 0.11
1 18 6 0.11
1 16 6 0.11
1 14 6 0.15
1 12 6 0.15
1 11 6 0.25
Base
16 32 6 0.11
1 30 6 0.11
1 28 6 0.11
1 30 6 0.11
1 28 6 0.11
1 26 6 0.11
1 24 6 0.11
1 22 6 0.11
1 20 6 0.11
1 18 6 0.11
1 16 6 0.11
3 14 6 0.30
No bleed stack
Shock Comp
12 44 12 0.20
1 38 12 0.11
1 34 12 0.10
1 44 12 0.25
1 42 12 0.25
1 40 12 0.25
1 38 12 0.25
1 36 12 0.25
1 34 12 0.25
1 32 12 0.25
1 30 12 0.25
1 28 12 0.25
2 27 12 0.25
1 25 12 0.25
1 24 12 0.25
1 23 12 0.20
Reb
6 40 12 0.20
1 29 12 0.11
1 40 12 0.25
1 38 12 0.30
1 36 12 0.30
1 34 12 0.30
1 32 12 0.30
1 30 12 0.30
1 28 12 0.30
1 26 12 0.30
1 25 12 0.20
Enjoy
FYI: The last 2 shims in the MID COMP measured differently for mine.
Forks MID COMP
3 20 8 0.11
2 17 8 0.11
2 13 8 0.11
2 11 8 0.2
1 13 8 0.15
2 11 8 0.25
2 12 8 0.3
2 20 8 0.11
2 12 8 0.25
Other than that, everything else in the fork and shock measured the same as you have listed. Thanks for posting the shim stack.
here's the uk spec.
comp
17x 32.11
30.11
28.11
26.11
24.11
22.11
20.11
18.11
3x 16.3
base
2x11.25
2x 20.11
reb
5x 20.11
13.11
20.11
18.11
16.11
14.15
12.15
2x 11.25
mid
3x 20.11
2x 17.11
2x 13.11
2x 11.25
13.2
2x11.2
2x12.3
2x 20.11
2x12.25
rear comp
7x 44.2
36.11
32.11
44.2
42.25
40.25
38.25
36.25
34.25
32.25
30.25
28.25
27.25
26.25
25.25
24.25
reb
5x 40.2
30.11
40.25
38.3
36.3
34.3
32.3
30.3
28.3
26.3
25.3
Edited by gavin lowes
put in wrong settings
Forks MID COMP
3 20 8 0.11
2 17 8 0.11
2 13 8 0.11
2 11 8 0.2
1 13 8 0.15
2 11 8 0.25
2 12 8 0.3
2 20 8 0.11
2 13 8 0.25
Reb
4 20 6 0.11
1 13 6 0.11
1 18 6 0.11
1 16 6 0.11
1 14 6 0.15
1 12 6 0.15
1 11 6 0.25
Base
16 32 6 0.11
1 30 6 0.11
1 28 6 0.11
1 30 6 0.11
1 28 6 0.11
1 26 6 0.11
1 24 6 0.11
1 22 6 0.11
1 20 6 0.11
1 18 6 0.11
1 16 6 0.11
3 14 6 0.30
No bleed stack
Shock Comp
12 44 12 0.20
1 38 12 0.11
1 34 12 0.10
1 44 12 0.25
1 42 12 0.25
1 40 12 0.25
1 38 12 0.25
1 36 12 0.25
1 34 12 0.25
1 32 12 0.25
1 30 12 0.25
1 28 12 0.25
2 27 12 0.25
1 25 12 0.25
1 24 12 0.25
1 23 12 0.20
Reb
6 40 12 0.20
1 29 12 0.11
1 40 12 0.25
1 38 12 0.30
1 36 12 0.30
1 34 12 0.30
1 32 12 0.30
1 30 12 0.30
1 28 12 0.30
1 26 12 0.30
1 25 12 0.20
Enjoy
Can you provide the float? Also is the compression piston post a subvalve that is not shimmed or an older style with only side bleed ports? Thanks.
here's the uk spec.
so the EURO has a 16 clamp and the US a 14 clamp ??? this would be a huge difference. long time ago a made a dyno of different clamps and was surprised
about how much the difference is between a 14 and a 16 clamp. to be sure I repeated this dyno this winter, same result...
Edited by kawamaha
Look at the shock comp stacks, huge differences
no conventional float, this bike uses the new kyb design.
It's being referred to as the MSV system I guess...
just opened my brand new '12 fork. this is how the new "float" works:
the gap is 0.30mm (measured with a non-digital caliper)
Edited by kawamaha
