02 cr250 header leak questions
hi there everyone i am thinking my fmf fatty is bent and leaking hence makeing my bike run lean.i replace the exhaust flange which was cracked right off up to the oring before i got it. with the new flange and oring it still leaks. im thinking the pipe is bent and not sealing. i was just woundering if havimg a leak in that area will make the bike run strange and ping and that sort of thing. cheers! thanks...
would deffinitly lean it out.
try to use some black RVT were the o-rings are. and by some i mean a good blob of it by.
