2012 SX250 info
For everyones info here the euro stacks for the 2012 sx250 2T
i have in a 2012 sx125 and a 250f so will post these at a later date
FORKS
4.6N 43 OD/485MM SPRINGS
19PSI N02 PRESSURE
28MM BASE PISTON
22.75 MID PISTON TRI-PORT
12MM DAMPER ROD
FLOAT 0.5MM
350CC OIL VOL
SKF OIL AND DUST SEALS!
BASE
24X0.10 X12
23X0.10 X2
22X0.10 X2
21X0.10 X2
20X0.10 X2
19X0.10
18X0.10
17X0.10
16X0.10
15X0.10
14X0.10
13X0.10
12X0.10
10X0.30
MID
20X0.10
20X0.10
20X0.10
18X0.10
18X0.10
16X0.10
14X0.10
10X0.30
18X0.45
8X6X0.30 POST SPACER
REB
20DX0.10
20DX0.10
20DX0.10
12X0.10
16X0.10
14X0.10
13X0.10
12X0.10
10X0.30
SHOCK
54N 63/63/260 SPRING
50MM PISTON TRI-PORT
18MM SHAFT
16MM ID SHIMS
COMP
44X0.20
44X0.20
44X0.20
44X0.20
44X0.20
44X0.20
28X0.10
44X0.20
44X0.20
44X0.20
44X0.20
42X0.20
42X0.20
42X0.20
40X0.25
38X0.25
36X0.25
34X0.25
32X0.25
30X0.25
28X0.25
26X0.25
24X0.25
21X0.25
REB
40X0.20
40X0.20
40X0.20
28X0.10
40X0.25
38X0.25
34X0.25
32X0.25
30X0.25
28X0.25
21X0.30
:smashpc:
MARK.
Thanks Mark!
What fork stop plate, base and reb?
Base looks like terrible 08 SXS.
Mark have u been out testing with this bike what do u think of the shock rebound is there enough high speed rebound and it's a 18mm shaft.
hey mark just a question mate, im 160 pounds without gear race MX and going to have a 2012 ktm 250sxf EU what spring rates do you recomend stock are 44/5.4, will i get the right rear shock sag with a 5.4 and are you still having troubles with CC foks diving and being a little soft on top?
id prob run a 52.5N rear and 4.4N front.
the forks dive due to the 0.5mm float - imo this HAS to closed up. with changes to the mid and the reduced float the fork works very well.
i added a little low speed, the high speed there is a little lacking, but its the formation of the stack - i found good results going to 0.2's under the 34 and adding a 26,24 &22 all 0.20.
:smashpc:
