How to grease and check XR650R swingarm bearings
Took my swingarm to a welding shop and he thinks he will be able to get my broken chain adjuster bolt out. While the swingarm is out, I figure I should check and lube the bearings. I am sure it is a newbie question, but how do I get the bearings out. Do I need any special tools? Thanks for any tips.
Bill
i got mine out bye using a socket that just fitted over the bearings and i also used a long extension bar.if that doesnt work you will have to get them pressed out.good luck
If like the post says...checking them,simply slide the inner bushing out after the spacer is removed.
Replacing them? Heat the outside with a torch and then push them out with a socket.
