Rear hydraulic brake problem
I changed my tire and when I went to put it back on my brake shoes were way too close to slide over the disc.
I took the caliper off and pushed on my brake pedal,then they totally locked together.
I then took the bolt/screws off to get the pads off,drained the hydrolic fuild and theyre still locked.
Any ideas?
Is it a suction thing,as in if I properly bleed the brakes it will release?
This is a china pitbike,but I thought this is a broad enough question to go in this forum.And I have a ride in a couple days w/ no way to get to a shop.
lol all you need to do is stick a screw driver in between your pads and push the piston back in......next time don't play with the brake pedal when the wheels off
theres no way that piston is moving,I tired the screwdriver thing already.thanks tho.
I'll see if its cocked.
thanks.
