She's last in line......:(
What have you planned?
- top end inspection
- change from '05 to '02 R cam
- remove HID lighting and re-install stock headlight
- remove battered skid plate and install Acerbis plastic
- remove stock battered rotors and install Braking Batfly oversize rotors
- remove stock battery and add litium (already done actually)
- replace Sunstar sprocket with Supersprox (50)
- replace front tire with MX 51 and Tubliss
- replace rear tire with IRC VE33 and Tubliss
- install R version radiator lowering kit: looks like it will work
- replace front .49 springs with .52
- replace rear 5.9 with 6.2 spring ( I have only 5mm static sag right now)
- service front forks (basic)
Paul will work on my bike, while I work on my Business.....
www.pacificaudiolabs.com
Interesting. I called ASR on tues just to see the turn around time for a basic valve job. Sounded like it would have only taken them a day once it was received at the shop and it would be shipped back. Will be sending the head there when the time comes..
If it's the week before a big race, it can take longer cause of all the bikes to prep.
Paul works 6-7 days a week most of the time.....
That is good to know! 7 Days a week would be nuts. Shops are only open Tues -Sat here.
When I saw Paul over Memorial Day weekend at 100's National he said the only days he gets off is when he comes out to pit his riders! Talk about someone living/eating/breathing dirtbikes!
Hi Kran,I see she still running the stock stand did u end up weighing it or another brand.
I haven't got that far yet....
CRF450X PARTS WEIGH-IN
STOCK FRONT DISC = .8
BRAKING 270mm = 1.3
STOCK REAR DISC =
BRAKING = 1.2
STOCK DISC BKT = .10
BRAKING OS BRKT = .2
UTAH SKID PLATE =
ACERBIS = 1.2
JAT HID =
STOCK light = 1.2
SUNLINE REAR SPROCKE= 3.4
SUPERSPROX X = 1.6
STOCK YUASA BATTERY = 4.3
LITHIUM = 1.3
REAR HD TUBE = 2.7
TUBELISS =
FRONT HD TUBE =
TUBELISS =
STOCK STAND =
ALT STAND =
You contracted ASR to do all of that ?
Here's the list......
REPLACE
• CHANGE UTAH SKID PLATE TO ACERBIS
• CHANGE ‘05 CAM TO ‘02 CAM
• Change from .49 t0 .52 FRONT SPRINGS
• Change from 6.0 to 6.2 REAR SPRING
• CHANGE REAR ROTOR TO BRAKING ROTOR
• INSTALL RADIATOR LOWERING KIT
• CHANGE SUNSTAR REAR SPROCKET TO SUPERSPROX
LITHIUM BATTERY (DONE)
• FRONT OS ROTOR (DONE)
• REMOVE OLD GRAPHICS (DONE)
• CHANGE FROM HID TO STOCK HEADLIGHT / BEZEL
• ADD AS RACING SHROUD GRAPHICS
• REPLACE BROKEN IGNITION KEY WITH NEW
INSPECT
• TOP END FOR WEAR
• REPLACE RINGS IF NEEDED
• VALVE SPEC CHECK
MAINTENANCE
• OILS
OIL FILTER
• COOLANT
TIRES
• NEW FRONT: CHANGE TO MX 51 - WITH TUBLISS -
• NEW REAR: CHANGE TO IRC VE33 110/100 - WITH TUBLISS -
Alt REAR : DUNLOP MX71 120/90/18
PARTS GIVEN
- REAR ROTOR
- IGNITION KEY
- RADIATOR LOWERING KIT*
- REAR SPROCKET
