Oil Ratio Question. 46:1 to 32:1
I suck at math.
If I have 2.5 gallons mixed at 46:1 how much oil do I need to add to make it 32:1?
Edited by Evmo
If you have 2.5 gal at 46:1, then you have 2.45 gal fuel and 0.0531915 oil (using the ratio).
So you want 32:1 by adding oil. So after you do this you will still have 2.45 gal fuel, but now 0.0531915 + X of oil. And now the total volume is 2.5 + X. Therefore using the ratio, ((2.5 + X)/33)*32 = 2.45. Therefore X is 0.026563; that is the amount of oil, in gallons, you need to add. :smashpc:
Duh...Mongo smash! 👍
In real time you add 3.5 ounces
Thank you sir!
Life is so easy with the metric system :busted:
Yeah I dunno why the English system is used at all anymore...Just makes life that much more confusing!
