Coil and stator ohm readings?
I don´t know how a PDF can be misplaced, but I only found the 450 manual. The 450 has a separate coil so it might be different from the 250 which is built in to the cap. But here is what the 450 manual says (maybe someone can copy/paste from the 250 manual?):
"Measuring Coil Resistance
If the arcing tester is not available, the coil can be
checked for a broken or badly shorted winding with an
ohmmeter. However, an ohmmeter cannot detect layer
shorts and shorts resulting from insulation breakdown
under high voltage.
• Remove the ignition coil (see Ignition Coil Removal).
• Measure the primary winding resistance [A].
○Connect an ohmmeter between the coil terminals.
○Set the meter to the x 1 Ω range, and read the meter.
• Measure the secondary winding resistance .
○Pull the spark plug cap off the lead.
○Connect an ohmmeter between the high tension lead and
the ground lead terminal.
○Set the meter to the x 1 kΩ range, and read the meter.
Ignition Coil Winding Resistance
Primary windings: 0.28 ∼ 0.38 Ω (at 20°C (68°F))
Secondary windings: 7.65 ∼ 10.35 kΩ (at 20°C (68°F))"
Found it, here are the 250 values:
Primary windings: 0.077 ∼ 0.104 Ω
Secondary windings: 4.56 ∼ 6.84 kΩ
To test stator;
○Disconnect the magneto lead connector.
○Connect the hand tester as shown in the table 2.
○Note the readings (total 2 measurement).
Table 2: tester + to black/red lead, tester - to red/white lead = 27.2 ∼ 40.8Ω
tester + to white lead, tester - to yellow lead 1.76 ∼ 2.64 Ω
To test magneto output voltage;
○Connect the hand tester [A] to the connector as shown
in the table 1, using the needle adapter set [C].
○Start the engine.
○Run it at the rpm given in the table 1.
○Note the voltage readings (total 2 measurements).
Table 1 Magneto Output Voltage
Tester Connections
Range Tester (+) to Tester (–) to
Reading
@4 000 rpm
tester range 250 V AC Black/Red
lead Red/White lead 40 V or more
tester range 50 V AC White lead Yellow lead 15 V or more
