Help tuning my suspension
Hi, All...
I kind of a noob, been on the bike for a couple of months.
An noticed that when I sit on the bike I compress the rear too much..
mi not all that big..
but I do always carry my tools and my camelback..
I guess my weight is about 180- 200 lbs.
I took my SAG measurements and name up with this.
Unloaded (bike on stand rear wheel int he air): 23.7 in
Loaded (without gear): 18.5 in
Bike Loaded (on ground without rider): 21.8 in
So mi race sag is about 5.2 in, my Free Sag (without rider) is 1.9.
So here come mi doubts..
I am an average trail rider, mi terrain is mostly open desert, my bike is a Honda CRF 250x so no track for me.. I like high speed trail ride and do enjoy the rough stuff..
I notice that my sag is kind of off... the previous owner of this bike was a 19 year old kit...
si I am going to try to adjust the preload to correct the sag.. what about the front forks.. should I try to change those or should I leave them as it is.. I DONT WANT TO TAKE MY SUSPENSION OF BALANCE??
Please advise!!
Yes you have way too much sag, adjust it down to 105mm (4 1/8"), than check your free sag you want to be in the area of 22mm (7/8") - 38mm (1 1/2") if not you will need a heavier or softer spring depending on what you end up with.
The forks you can consider this sag 64mm (2 9/16") - 85mm (3 5/16"). Static should be somewhere around 25mm (1") - 38mm (1 1/2").
I think you will find this good for the desert.
Do yourself a favor switch over to mm.
Measure and repost.
Good Luck
