Suspension Setting Compilation
I haven't seen a post like this yet, and I think it would be a great way to spread some knowledge. Post your current setup as follows:
Rider info
Rider Weight (Specify w or w/out gear):
Rider Height:
Rider Skill:
Preferred Riding Style (MX, Woods etc..):
Bike Setup (All clicks are in; e.g. clicks in from all the way out):
Bike Year (Assuming all CRF450s):
Rear Spring Rate:
Preload:
Front Spring Rate:
Front Compression Clicks:
Front Rebound Clicks:
Rear High Speed clicks:
Rear low speed turns:
Rear rebound clicks:
Satisfaction rating (out of 10):
Notes: Notes regarding your setup. What you could do better, what you like, what you hate, who did your suspension, overall satisfaction rating, triple clamps, etc...
I'll go first:
Rider info
Rider Weight (Specify w or w/out gear): 200lbs w/out gear
Rider Height: 6'3"
Rider Skill: Intermediate
Preferred Riding Style (MX, Woods etc..): MX
Bike Year (Assuming all CRF450s): 2011
Rear Spring Rate: 5.7 kg/mm
Preload: 110-112 mm
Front Spring Rate: .52 kg/mm
Front Compression Clicks: 16
Front Rebound Clicks: 18
Rear High Speed clicks: 21
Rear low speed turns: 1 1/2
Rear rebound clicks: 19
Satisfaction rating (out of 10): 8/10
Notes: The stock suspension was unrideable. Getting the front stiffened up made a huge difference, and got me to the point that I could actually do some real R&D. The suspension was re-valved twice by Hitchcock Industries in Denver, and I would highly recommend him.
I think the rear valving could be stiffer, I am having Hitchcock take a look tomorrow to see if it's a valving issue or if the oil has degraded. It is great in ruts and bumps, but it doesn't take a big hit really well (kinda like Rhianna. ziing!). As a taller rider, I opted not to get the lowering link, since I want to maintain as much travel as possible. We worked to balance the bike by bringing the front up, rather than bringing the rear down.
