2004 klx 125 bogs when throttle hit
2004 klx 125. idles with choke on or off, only revs with choke on. Have drilled out the adjustment and little changes with position from .5 to 4 turns out. tried leaner and fatter idle and main jet with little change. Cleaned carb multiple times. There is no needle clip adjustment that can be made with the design. If i cover the intake side of the carb with part of my hand i can make it rev
