Drz intake boot
Hi i was wondering if anyone know the dimentions of the head to carb intake boot (mm) i want to change the intake manifold becouse its worn a bit so i can order the correct bore hose ! also will a sillicon hose like those they use on intercoolers ( like this one http://image.made-in-china.com/2f0j00tMCQeSKaYHqR/Coupling-Silicone-Hose.jpg ) will do the work or the intake uses a special part ?
i have an 1st gen 41mm fcr
This part here
also becouse my air filter hits the frame will be any problem if i use a 45 degree elbow hose to mount the air filter ? turbulence etc ?
like this one http://www.ebay.co.uk/itm/150616703765?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
thanks
I just measured a brand new boot i just got in the mail. looks to be about 48mm ID on both ends.
Hope this helps
-Dan
Dan thanks i just fixed my boot with a silicon collar like this
scaled.php?server=26&filename=1004429k.jpg&res=medium
yes this is a 41mm fcr feeding a CCM 404 drz E motor on stock CC
as for the jetting i really dont remember :smashpc:
i do remember the pilot/slow air jet is 100 the main air jet is 200
i thing the main jet is 160
but i really dont remember 👍
i know 👍 i have to make some jetting when i find some free time
but i dont have any idea about jetting fcr's so i dont have any idea from what jetting should i start :smashpc:
i would appreciate any suggestions on what jetting to use
its the drz-E engine ( cams, head, compression, ) and a pro circuit T4 exhaust
the filter needs cleaning :busted: im waiting a K&N recharger kit to clean it
It's going to be hard to set that up without a gas analyser/dyno...
The carb is too big for stock cc ...That pod filter system won't make jetting easier....
How does it run?
well the funny thing is the the bike runs pretty nice as is now :S
and it doesn't bog and keeps pull until the redline
i might go on a dyno to see whats going on with this jetting
175 main jet
48 pilot
65 choke
200 main air jet
100 pilot air jet
this is my jetting :smashpc:
and here is the pod after cleaning
Edited by Vatos_locos
