help please
I have just bought a 2008 te450 and after taking the computer harness off and swapping tail light harnesses to and fro trying to get blinkers to work after putting everything back to how it was when the bike was working fine, it will not kick over. Electric start works and motor turns over but will not run. after check the spark plug i assume it has fuel because the plug was a little wet but there is no spark on spark plug, i got a new spark plug and still no spark. any help is good help thanks...
Check your coil connections...if this is loose it would explain the lack of spark.
swap the fuses under the right side (as I remember) number plate (3 of them). the Husky uses some goofy shared electrical system. You might have crossed a wire when swapping units. Plus the stock fues are junk. If one of them is blown, the motor will crank, but you will get no spark.
hey guys thanks heaps for the replies, i found out it was a blown resistor on the o2 sensor bypass, very irritating. cheers
