Tip for Air Filter Installation
a tip passed down to me was that a TTR's weak spot is the air filter and i was told this helpful piece of advice..
1) just clean your air filter as you would.
2) when re-oiling the filter (use the bottled oil) saturate it then squeeze it out but leave it in a clean place out of the air box and off the frame to dry for about 24 hours.
after that it will be more likely to catch that finer dust and should give you a bit more life from the engine.
