Kawasaki 08 carbureted Teryx
WHen riding my Teryx and I let of the accelerator the engine pops and backfires. What is causing this and how to I prevent it from happening. The only modifications I've done to the vehicle is replace the stock air filter with a twin air filter and add an FMF slip on muffler. There were no advisments that jetting needed to be changed with installation of either of these items. Any help with this problem will be appreciated.
Thanks, Yobilly
Frist try adjust on the carburetor the pilot (air) screw.
Have you check your Valve Clearance?, It also possable that your Pliot Jet maybe just a tab to small which also cuase that when let off the accelerator the engine pops or backfires this is know lean condition.
