TT600 Belgarda
Hi guys, new to this so please be patient.
Just purchased 1999 TT600 Belgarda (cheap)
Problem is it won't idle and you have to blip the throttle to keep it running.
Backfires continually and not sure where to start, previous owner left it sitting in the shed for ages and says it didn't do this before.
Any help would be appreciated.
Welcome .
Probably better pull the carb(s) and clean the mung out of every passage and jet , particularly the idle circuit . The backfire is indicative of bad insulators ( rubber and metal parts that connect the carbs to the head ) allowing air in , leaning the mix .
Started on the carby and found the mixture screw is MIA. Tried one from an earlier model but still playing up, could mixture scews be different between models or should I be looking further.
What carb does the earlier model have compared to your bike ? I suppose they could be different , but from the pics I've seen they seem very similar . I haven't found any parts fiche to verify model usage . I did find a service manual for a 2003 model ( wouldn't think there would be much difference from a 1999 ) that you might be interested in :
http://issuu.com/nanorecius/docs/1_yamaha_tt600re_5ch5_2003_service_manual
Pilot jet blocked and mixture screw is model specific. Can't find one in Adelaide so have to wait for one from Sydney.
Thanks for the help
