oem circlips in wiseco piston?
Just got a wiseco 13.5:1 piston kit and I went to install the circlips and they are way to small, pin can slide right over them. Just wondering if the oem ones will work in this piston?
since it is the same size piston the wrist pin is going to be the same size, but I don't know about the groove the circlip go's in it might be to small and cause the circlip to come out while riding.I would call wiseco and ask them about it.they may have sent you the wrong circlips, when I bought a piston kit from them they sent me the wrong gasket kit
diameter of the wire is different, it won't work, don't try it, only bad things will happen....
as mentioned above use only wiseco circlips
