Consequences for putting in too much oil?
I've heard you can blow out seals and gaskets, but i'm not sure if this is true. Anybody had any experiences with this? I didnt do it, but its hard to tell how much more to put in on my bike.
Thanks
~Adam
I used to over fill my sxf450 all the time. It pushed oil out of the countershaft and valve cover until it reached the right amount lol. I never had any other issues so my assumption is it should be fine. I would just tell you to measure it and call it good, normally its 1100cc for a 450.
it will also blow oil out the crank case vents on some bikes then putting oil all into the air box so dirt can stick to it and make a good mess. i just say use the right amount of oil to start with and check it before you ride because these new bikes tend to consume a little oil
Besides blowing out gaskets and seals, over filled oil can foam. Foaming oil looses it’s lubricating qualities.
