05 engine case
Anyone ever have engine cases welded or repaired in some way? My 05 RM 250 left side engine case cracked around the counter shaft after the bearing blew apart. If you have a left side case let me know.
im sure you could get it repaired, but if you have to replace one case, you have to replace both, cases are cut as a matched set and you could run into some problems with an unmatched set, at least on a paper gasket motor, if it were a single sump, silicone center case gasket 4 stroke, you mightr be ok with one, but your best bet is to get a set.
