kickstand mod
I started with grinding out the partially covered hole on the bottom, moved on to drilling 3 holes in the support/brace connected to the bottom plate. Picked appropriate size drills (small,med,large) don't go to big or the brace may collapse. This mod was done to remove weight at the of the stand. To finish off the changes I removed 1/8 inch off the upper stand stop. Together I believe less end weight and having a slightly higher retracted stand I feel that going over jumps I don't have the stand bouncing up and down. I don't have the stand switch installed but if you do and use your z in the dirt this mod may help with the intermittent cut outs.
