Honda 1986 Trx200sx
I have a 1986 TRX200Sx and I am new to this. I was wondering what kind of modifications I could do to it to make it faster and handle better. What should I dig into first to make it cheap and affordable.
Thanks!!
TRX200SX I belive you have look at ATC200 and XR200 performance parts things like Cam, Tab Higher Compression Piston, Bigger Carb, better Muffler other then there not much you can do with motor.
If you have Bad A arm Bushing, Wheel bearings, Tie Rod Ends, Swing Arm Bearings/Bushing, Rear Axle Bearings and Shock Bushing this can cuases really bad handle.
As for more better handle widing the Front +1/2 on A arms and Rear Axle and longer wheel base may help but that not cheap nor affordable and if ask me it waste money you would be better off looking for a Real Sport Quad like Honda TRX300EX or TRX400EX.
