Mikuni tmx 02 cr250?
can anyone tell me how to get the bowl off my mikuni carburator. the was one small bolt on the bottom. and looked like anouther bolt hole beside it with no bolt in it. i took the small bolt out and the bowl doesnt want to come off. its almost like its sealed on with an adhesive of some kind. if anyone knows anything please let me know thanks cheers.!
there should be 4 phillips screws. remove them and pull the bowel off. sometimes i tap the bowel with the handle of the screw drive if the "O" ring is stuck to the carb base. careful not the lose the float hinge pin. they sometimes slide out.
This ^ One small Phillips screw and the drain plug that's it.
ohhh thats it. diferent then the old bikes ive worked on. that makes sence now thanks alot.
You have have to remove the drain plug.
I struggled with mine the first time also. Felt pretty dumb once I removed the drain plug... :smashpc:
