jetting or accelerator pump
I have a 2007 yz450f, runs like a champ... but at low rpm if i jump on the on the gas it will stall out for a second then jump back to life...? where to start?
AP pump.
Did you confirm you have a strong squirt?
Did you put in a stiffer AP spring like the Merge Racing one?
Did you check and set the AP timing EXACTLY per the manual?
What size leak jet? #60 or smaller?
