Cracked/broken case
Just picked up an 01 cr125 for a project for me and a bike for the wife. I noticed the case Is broken right where the swing arm bolt goes through it. Just about the whole left side is missing. Can I buy just the let side or do I have to buy both side? I plan to go through the motor top to bottom this winter and Am just wondering if I need to replace both sides. Sorry for the ignorance, haven't owned a two stroke in a while and I have never had an issue like this.
No need to replace the right side as long as its not broken, be sure to check the mating surface out well...
Id check out ebay for a cheap used one...
You could probably get it welded (broken case) if you would like. Just a suggestion.
Nah, just replace whats broke and check the other side for hairline cracks or obvious damage.
