2000 YZ125 Gear shift lever
Does anybody make a steel gear shift foot lever?
Or does anybody make an aluminum one that doesn't loosen up and strip every ride?
Im a firm believer of the Sunline alloy lever and run it on every single bike I own, never stripped one or had to tighten it until I took it off. A little loc-tight on the bolt goes a long way too.
If they keep stripping might be time to change the shift shaft or stop jumping on them to shift. One or the other not sure which one is your issue though.
shift shaft is fine, and i'm not jumping on them to strip. this is the second of the msr ones that i have had on it that are about to strip or have stripped.
