YZ hub on CR
Found a cheap YZ hub from a 01 or 02, would it fit my CR 06?
I counted the spoke holes to be 36 as i also have 36 in the front on my CR.
Any difference in axle diameter or width of hub?
Thanks.
This is what it says in the description:
"New/Unused Yamaha Yz250 front hub spacers and disc, not 100% what year its off but believe it to be approx 2001 or 2002 though I believe its the same hub as was used up to 2006/2008? it is also likely to fit other models eg 125 426 450 but please check first, the identifying number on it is 194. The brake disc had very light use on another wheel but the hub itself has never been used."
