Low down Bog Problem after Air filter change?
Hey
My 2007 crf450x Bike has developed a bit of bog after just recently changing over to the No Toil cage setup i.e. not using the standard mesh backing any more. Really noticeable when hitting hill climbs in 2nd today went to grab a bit of throttle to wheelie over a rock ledge and it flamed out nothing! Caused me to crash out:banghead:
My current jetting is
168 main
45 pilot
standard leak jet
NCVS needle
Fuel screw 2 turns out
Lexx Slip on pipe
R header
Air box cut
Does the new filter set-up require a change to my jetting at all?
Thanks
Hey
168 main
45 pilot
standard leak jet CHANGE TO A 50 LEAK
NCVS needle
Lexx Slip on pipe
R header
Air box cut
Thanks
Change the leak, and inspect your accelerator pump linkage to see if it's a new or old version (most 2007's came with the upgraded linkage). If it's the old version
you need to change the apump linkage return spring http://www.mergeracing.com/products/AcceleratorPumpSpring.php
If it's the new version
you don't need the spring.
In both cases you need to adjust the linkage per the manual to get proper squirt timing.
Hey
168 main
45 pilot
NCVS needle
Lexx Slip on pipe
R header
Air box cut
Thanks
Thanks Krannie
Forgot to mention I have a 2006 R cam and a aftermarket accelerator pump cover.
Do I still need to go the 50 leak jet? Do I need to take the carbie off to do this?
Thanks Krannie
If it is a Boyeseen adjustable leak jet, you might have to chuck it, cause some were built so poorly, they made problems in the apump system.
The R&D version works great.
Nope it was a cheapie off RMATV I think it was called a raven afterburner or something?
So do I need to take the carbie off to do the leak jet. I would imgaine you would have to, to take off the fuel bowl??
Did the bike run fine just prior to changing to the no toil unit? If so are you sure you didn't just over oil the filter? Is there oil on the bottom of the air box?
I put the 50 leak jet in. Still getting plenty of bog down low.:bonk: But its only when I run the non cage filter. I have also gobe with a 48 pilot. My accelerator pump is the newer version but I have not put the o-ring in.
Do I need to go richer on the needle? Currently I am at 3rd clip from the top. Maybe I should just run the caged filter and forget about the other.
You first need to verify proper accelerator pump operation.
Loosen the rear air boot, remove the muffler, tilt up the sub frame:
Watching closely the intake of the carb, watch the stream of fuel come out of the brass nozzle in the bell of the carb. It should shoot all the way into the head, just missing the slide. It should squirt every time. If it hits the slide, turn the adjustment screw under the black cover clockwise a 1/2 turn at a time until is just misses the slide.
You probably have a clogged acclerator pump nozzle.
