2004 yz 250 fork swap question
I have found a 2008 250 f fork with clamps and also a 2009 fork with clamps on ebay. Has anyone bolted one on to a 2004 yz 250 two stroke.
i think the triple stem is different height, also not sure but isn't there i a mod from a steel frame to a alloy frame stuff too, that info is in the faq in the yz section, i was messing with mine and finally found some good forks from a 450.
your right bobby...the 250f steering stem is different its about 8mm too short and wont let the nut thread all the way. i just put a 08 front end on my 04 and i just went ahead and bought rg3 clamps for the 04 yz250
If the stem is the same diameter (likely), you should just be able to press the longer stem out and press it into the other triples.
