Stuck Valve
My 04 crf450r has a stuck valve how much would it cost to get fixed? or is there a way to do it yourself?
Depends what damage it did, since it didn't break off then your cylinder and cylinder head are probably ok. You will have to check the piston, and should check to make sure your connecting rod and crank aren't bent. Best case scenario, you will have to replace the valves and the valve guide.
