WHERE CAN I GET A S-7 nozzle
hi i want an s-7 nozzle for my mikuni tmx carb on my CR250. can i jus order one from the honda dealership or do i have to go somwheres else thanks.
What nozzle comes in the 02's stock? I thought I remembered taking a 7 out of my TMX when I installed the JD kit... Before my PWK swap.
02 comes with a s-9 noozzle. JD kit used to supply a s-4 but now he has changed the needle to not need the nozzle replaced as he could not get the nozzles reliably. I just installed the new JD kit in my 02 and it worked great. I would recomend it unless you like to tinker with carbs and jets. No matter what you do with standard jets and needles you cannot get the multi tapered needles like JD supplys and the accompanying results. However many people get their TMXs to run great without it.
