Getting Yoshi slip-on tomorrow...jetting settings?
I have a plated 03 400E (previously ridden hard in dirt only) in Mass...used trick dual sport to get legal. Bought Warp 9 SM kit...cleaned it up a bit and rode it today...very fun :-) Probably won't see serious dirt again.
Tomorrow i'll be buying a yosh slip-on and ripping out the snorkel. I already bought the JD jetting kit. Any suggestions as to what I need to do with the jetting to maximize performance (will the performance gain be noticable) ? Thx...
I presume it has the slant body fcr???...
With snorkel removed...
160 main jet
200 main air jet
100 pilot air jet
EMN needle clip 3 or JD Blue needle clip 4 or stock DXP needle clip 5
45 pilot jet
2.25 turns fuel screw
Remove the coast enrichener.https://thumpertalk.com/forum/showthread.php?t=726110&highlight=coast+enrichener+removal
Do the Eddie Mod..https://thumpertalk.com/forum/showthread.php?t=890079&highlight=eddie+mod
To make easier pilot circuit tuning I recommend you get a R&D Flex Jet remote fuel screw...You will need to slightly enlarge the fuel screw orifice on the bowl.,(with a drill) to install the Flex Jet.It's an easy job...
http://api.viglink.com/api/click?format=go&drKey=294&loc=http%3A%2F%2Fwww.thumpertalk.com%2Fforum%2Fshowthread.php%3Fp%3D10626773%23post10626773&v=1&libid=1314872488816&out=http%3A%2F%2Fshop.thumpertalk.com%2Fcatalogs%2FParts_Unlimited_Offroad_2009%2Fdefault.asp%3Fp%3D817&ref=http%3A%2F%2Fwww.thumpertalk.com%2Fforum%2Fforumdisplay.php%3Ff%3D25&title=DRZ400e%20Jetting%20-%20ThumperTalk&txt=http%3A%2F%2Fshop.thumpertalk.com%2Fcatalogs...ault.asp%3Fp%3D817&jsonp=vglnk_jsonp_13148725794081
160 main jet
200 main air jet
100 pilot air jet
45 pilot jet
Thx Craigo...slant/mx??? Whatever was stock with 2003 E. I also currently have 15 tooth up front and 45 rear and the bike revs at speed and is granny like in 1st...so along with jetting and yosh slip-on, I bought a 42 tooth rear that will be going on this week. I hope the pipe and jetting will help pull off the higher gearing.
