2000 Husqvarna 610SMS questions
Hey everybody, picked up this 2000 Husqvarna 610SMS yesterday and its my first supermoto and I have questions regarding maintenance. What's the best brand and weight of oil have you guys found that works the best for durability? Also, more bike specific, how many drain plugs are there and how is the filter changed? And finally, how frequently should the oil be changed and valve checks be performed for normal operation?
And does anyone know what this wire with two connectors does?
I believe those wires are connected to your safety switch on your clutch. When you pull in the clutch it actuates a plunger on the side and completes a circuit allowing you to use the starter. It prevents you from hitting the starter button while in gear without the clutch pulled in. If it starts giving you trouble just pull the wires out and tape them together completing the circuit.:smashpc:
