300EXC carb vent hoses question
Hi there, I have a 2011 300EXC. I want to run via T joints carb vent hoses into the air box to help with vapor lock for water crossings. There appears to be only one vent hose for the float bowl coming out the bottom of the carb(right side) do I run vents off all other hoses on the carb apart from that single line? Anybody know?
Thanks in advance
Guy
The hose at the bottom of the carb is a drain from the float bowl. If your carb has a 4 vent system, there should be 2 vent lines which run over the top of the carb and down the opposite side. These can be re-routed into the air-box.
Great thanks, yep four vent with two going over the top. Will t joint those ones.
Cheers
No need to T them. Just route these 2 back into the airbox.
