Conventional fork guys....
I know it sounds crazy but any of you guys with the 96-98 conventional forks..... can you measure the distance from the top of the lower leg to the bottom of the lower fork clamp for me (the shinny part of the fork)?
I've been running a set on my 2005 RM and a member on TT noted there may not be enough clearance for the fork to compress all the way when using the stock 05 fork clamps. Mine don't appear to be hitting but after taking a measurement of my set up it looks like the fork is only traveling 11 inches vice 11.4. Just curious...thanks!
take the springs out and compress the forks on the bike if they don't hit and go through full travel you have your answer about if you are getting full travel without hitting your fender.
