I've done it this time! need help!!
I took apart my oil screen for cleaning on my 07 kx 450 and was putting it all back together and one of the alignment pins fell into the big oil passage under the flywheel.? Am i screwed or is there a way to get this out? thanks in advance! :smashpc:
Edited by 2strokerider15
misspelling
if you did wash it further into the motor, its probably somewhere around the the oil pump feed or something. maybe around the tranny, theres soo many places that it could be.
if you try the magnet thing though, you may have to get new gaskets. 1 of the gaskets is a metal one, so you might get lucky and be able to re-use that one. and i can't remember if the other is paper or not.
