CR gas tank
I just like the look of the CR250s gas tanks with the scoops on the front. does any one knoe if they would fit a XR250 its a 92. Does any one have any pics of one on a XR
It takes quite a bit of work to fit a aloop kit to a pre 96 XR
Need to make spacers out of marine plywood to fit between frame and seat base
I screwed this onto seat base.
Also need custom tank mounts and seat mounts.
For a pre '96 XR250R you'll need to use the kit for a XR650L. Converting it should be simple and straight forward. 🤣
It will also allow some extra room so USD forks will fit without interference. :smashpc:
Here's a picture of my '87 XR250R with it's secret identity. :busted:
TNT, do you have the link to the thread you posted about the 250/650L gas tank seat interchangeability you posted a while ago??? Id love to check it out for future ideas. Thanks
Those look nice but I realy like the look of the older CRs 85-?. I love the colors also red with blue seat. I looked at frams on ebay 85-? CRs, and 92 ish XRs and the top tubes look similer.
The frame isn't the issue. The tank from a CR won't fit over the engine.
The exhaust side possibly high enough but the other side hangs way low.
The CR125, CR250 and CR500's all have the same design.
