best shock for crf 250'10
for my fast 70 kg rider i ade this stack
44x0.20 12
30x0.10
42x0.20 3
40x0.25 2
38x0.30
36x0.30
34x0.30
32x0.30
30x0.30
28x0.30
27x0.30
25x0.25
23x0.30
reb
40x0.20 5
25x0.10
40x0.30
38x0.30
36x0.30
34x0.30
32x0.25
30x0.25
28x0.25
26x0.20
5.0kg/mm
11bar press
4mm spacer lower in
105 sag
Too stiff on com side and too fast on reb side...too far from the stock set up:bonk:
it,s very good with the hi speed cam i make a video the tyre have an impressionant grip and fly on the hi speed bumps , no bottoming on landing ramps ,the reb is slow then stock on ls
with the 5.0 5 face shims on rebound is ok but 6 is common as well allowing you to run the rebound further out so you have more free bleed making the comp better
fork
32x0.15 2
28x0.10
32x0.10 17
30x0.10
28x0.10
26x0.10
24x0.10
22x0.10
20x0.10
18x0.10
16x0.10
14x0.10 7
mid
20x0.10 5
18x0.10
16x0.10
14x0.10
11x0.30 2
17x0.30 2
reb
20x0.10 5
12x0.10
18x0.10
16x0.10
14x0.10
11x0.25 2
maxima 5 oil
370cc
merge progressive ics spring
But marcus that's still alot of hs comp in the shock even with that amount of bleed. Cardinale199 what float u running on the mid
yes but for him it's working well , it would be too firm for me as would his fork , it's a setup that will give the rider lots of feedback , some people like that
the mid float is 0.20 the shock have stiff hs because in italy the track have a lot of step bumps in acceleration zone .it s for keep the rear high
You are right that it needs more low speed reb... but...
That bike needs bigger reb cross over until you can go further than 6-9 clicks
Those hard pack tracks in Italy really needs stiffer shock set up...but if you don't have enough ''bleed'' on your com stack it will kick hard and can cause cavitation.
Edited by Jusa
also looks very stiff to me, but if that's what you like...
