KXF link on a KX??
Has any one tried putting on a KX250F linkage 2007 on a 2007 KX250? I know the length is the right length to fix the problem of god awful handling, I just need to know if it will fit. if it is the right length I can then put on a KX450F pro circuit linkage and make it really low and stable.
OK i did and I almost gaurantee my dad aint fallin for that one. do you know a place that sells them? I have looked everywhere...
I actually just got a PC link from OEM cycle. Need to remove my spacer and install it this week.
Thr 250f link will fit, but its way too long and your tire will hit the fender.
Its .5 mm longer than the procircuit one which is 3mm longer than OEM.
What year four stroke are you looking at?
the link that will fit is from 04-05 (IIRC) 250F's. I compared bearings, seals, bolt lengths, etc on the Kawasaki parts diagrams. the issue is the link is too long. Again, IIRC, I got a measurement of about 6" which is an inch longer than stock. You will definately hit then.
