YZ125 Clutch cable adjusting
Aight so i putt on a new ASV lever on my 2000 YZ125 and the clutch was actin fine untill i put the new lever on so then i bought a new cable cuz mayb i thought tht was the prob. Wen I was adjustin it no matter what if it was tight and perfect feelin wen i wood hold the clutch in and have it in gear and try and roll it it wood lock up like i had the clutch out. WAT IS GOING ON???? Is there a certain way i have to adjust it or is it something else?
:smashpc:
should be a few mill play in the lever if it still does the same i'd check the clutch, sounds like the pressure plate isnt working properly. could be a number of things really so take off the clutch cover and have a look..
Edited by wardy123
spelling mistake
